-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   6th Gen ('00-'05): 2001 monte p1404 please help (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/2001-monte-p1404-please-help-39214/)
01navyss Oct 3, 2012 10:49 PM
What would cause this code? thank you
monte carlo 3831 Oct 3, 2012 11:00 PM
https://montecarloforum.com/forum/im...h/misc/tag.png https://montecarloforum.com/forum/im...subscribed.gif https://montecarloforum.com/forum/im...isc/sticky.gif Sticky: GM OBD II Trouble Code List
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
01navyss Oct 13, 2012 11:35 AM
Will a new egr valve fix this? I took mine off and cleaned it and the light went off for about a week then came back.
Space Oct 13, 2012 12:08 PM
Not if something else is causing your ERG to clog & send a code ? Does your Monte have the factory `Cat ? It could be bad ?
Check back to see what our expert tech's post about your problem...
***Thanks `Chris for posting the Codes & helping a member 4-Sure :thumbsup:
01navyss Oct 19, 2012 02:25 PM
It will go off for a little while when I clear it then come right back
