2000 MC, 3.8 Crankshaft pully won't come off! Bolt is already off!
Hello all -
I have a 2000 Monte SS and I need to replace the crankshaft positioning sensor. I was able to get the bolt off with a breaker bar and the starter, but now I can't get the pulley off. It won't budge. I've tried wd40, pulling as hard as I can, hitting it with a rubber mallet, ect.. Anyone know how to get it off? My haynes manual says it doesn't need a puller kit. :mad: |
Well dump the WD40 and go for a anti seize lubricant. Try hammer again. then use pulley puller. Just cause it says you don't need one doesn't mean you shouldn't use one.
Anyone know how to get it off? My haynes manual says it doesn't need a puller kit. This is what I used: http://www.zzperformance.com/grand_p...=339&catid=111 |
| All times are GMT -5. The time now is 04:31 AM. |
