06 MC. 5.3 hard shift 1-2 gear
HI all,
My 2006 ss just started doing a funky hard shift between 1st and 2nd gear and sometimes 3rd. This happens while in drive but not when I manually shift. I've had the fluid flushed about 4 months ago with no probs until now. The fluid now is clear, full and not burnt. If I drive it real easy, it does minmize the hard shift greatly. Any ideas out there? Thanks, Jeff |
are you setting a code?
No check engine light...havn't checked for code
I know in my 03 Monte It was doing something very similar but in 2-3 and ended up being the valve body
