-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Engine Build: The 01 MC SS Sleeper LS4 (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/01-mc-ss-sleeper-ls4-26283/)
PacerSS Feb 22, 2011 10:07 PM
This is awesome! I like it alot. I wish I could change my dash out like that I love the shifter too.
Dredd Feb 22, 2011 10:10 PM
Originally Posted by Montess2k (Post 299364)
Very cool indeed great project, any videos of it running, take it to the track yet?
Props on a great and original setup,
Joe
Hey Montess2k,
Thanks, and I haven't did a video yet but this sleeper is going to surprise some people. I plan a trip to Raceway Park in Indiana and locally here to Sacramento Raceway to get some times in!!
Dredd Feb 22, 2011 10:14 PM
Hey PacerSS,
You can actually use the whole center console and the shifter bolts and connects right to your shifter cable. You can probly get the whole setup for about $150.
Dredd Feb 22, 2011 10:44 PM
Originally Posted by bbengineer (Post 299162)
It's nice to see some actual real info on the swap... I have a bunch of questions
One quick note... the cluster doesn't store the mileage in 06+, it's in the BCM.. that's why the mileage matches :)
1) Do your airbags work? (meaning, do you get SDM codes?)
2) What doesn't work correctly? Are the things that do not work fixable?
3) You replaced your gas and brake pedals for the drive by wire, correct?
4) Did you replace the entire dash wiring harness? Did you replace the entire body harness (save the front and rear lamp portion)
5) Do you install the amp/etc from the 06+ Monte?
6) Do you have a list of the spliced connections and the wiring colors?
Thanks
BBEngineer
PS: While I am not a big fan of the LS4 swap... Nice work on getting it done!
1) Do your airbags work? Yes just need to get passenger side seat airbag (meaning, do you get SDM codes?) No
2) What doesn't work correctly? The only component from my original MC SS that does not work or I'm not sure if it working is my Onstar which is pre-2006 so it analog and obsolete. Are the things that do not work fixable? Yes a simple upgrade to a digital Onstar system with GPS.
3) You replaced your gas and brake pedals for the drive by wire, correct? YES and both bolt right in. The only mod I needed to do is drill one hole for the Brake Pedal Positioning Sensor which also operates the brake lights.
4) Did you replace the entire dash wiring harness? YES Did you replace the entire body harness (save the front and rear lamp portion) Correct and I spliced both with portions of my 01 MC SS wiring harness to get fully operational tail lights and head lights with fogs.
5) Do you install the amp/etc from the 06+ Monte? YES
6) Do you have a list of the spliced connections and the wiring colors? Not written down anywhere but the wires are marked so i guess i could put it in a script or how-to.
PacerSS Feb 22, 2011 11:09 PM
Could it be possible to keep the upper dash of the 00-05 and cut it to mate to the radio and lower part of the 06?
Dredd Feb 22, 2011 11:11 PM
Originally Posted by punisherss (Post 299208)
Amazing...would you want to sell me the ash tray setup in the front cupholder there from the old dash? lol
Sure just let me know where to ship it to.
Dredd Feb 22, 2011 11:17 PM
Could it be possible to keep the upper dash of the 00-05 and cut it to mate to the radio and lower part of the 06? YEP!!
RickAKATed10 Feb 23, 2011 09:06 AM
This is one sweet project. Keep up the good work!
Dredd Feb 25, 2011 10:41 PM
Originally Posted by ChibiBlackSheep (Post 299108)
Great post :)
Heres the link to a video of DaMonte running http://www.fquick.com/videos/They_sa..._be_done/10138
monte carlo 3831 Feb 25, 2011 11:02 PM
it can't be done man... that is totally badazz!
