Engine Build: The 01 MC SS Sleeper LS4
Old Feb 22, 2011 | 10:07 PM
PacerSS's Avatar
This is awesome! I like it alot. I wish I could change my dash out like that I love the shifter too.
Old Feb 22, 2011 | 10:10 PM
Dredd's Avatar
Originally Posted by Montess2k
Very cool indeed great project, any videos of it running, take it to the track yet?
Props on a great and original setup,
Joe
Hey Montess2k,
Thanks, and I haven't did a video yet but this sleeper is going to surprise some people. I plan a trip to Raceway Park in Indiana and locally here to Sacramento Raceway to get some times in!!
Old Feb 22, 2011 | 10:14 PM
Dredd's Avatar
Hey PacerSS,
You can actually use the whole center console and the shifter bolts and connects right to your shifter cable. You can probly get the whole setup for about $150.
Old Feb 22, 2011 | 10:44 PM
Dredd's Avatar
Originally Posted by bbengineer
It's nice to see some actual real info on the swap... I have a bunch of questions
One quick note... the cluster doesn't store the mileage in 06+, it's in the BCM.. that's why the mileage matches
1) Do your airbags work? (meaning, do you get SDM codes?)
2) What doesn't work correctly? Are the things that do not work fixable?
3) You replaced your gas and brake pedals for the drive by wire, correct?
4) Did you replace the entire dash wiring harness? Did you replace the entire body harness (save the front and rear lamp portion)
5) Do you install the amp/etc from the 06+ Monte?
6) Do you have a list of the spliced connections and the wiring colors?
Thanks
BBEngineer
PS: While I am not a big fan of the LS4 swap... Nice work on getting it done!
1) Do your airbags work? Yes just need to get passenger side seat airbag (meaning, do you get SDM codes?) No
2) What doesn't work correctly? The only component from my original MC SS that does not work or I'm not sure if it working is my Onstar which is pre-2006 so it analog and obsolete. Are the things that do not work fixable? Yes a simple upgrade to a digital Onstar system with GPS.
3) You replaced your gas and brake pedals for the drive by wire, correct? YES and both bolt right in. The only mod I needed to do is drill one hole for the Brake Pedal Positioning Sensor which also operates the brake lights.
4) Did you replace the entire dash wiring harness? YES Did you replace the entire body harness (save the front and rear lamp portion) Correct and I spliced both with portions of my 01 MC SS wiring harness to get fully operational tail lights and head lights with fogs.
5) Do you install the amp/etc from the 06+ Monte? YES
6) Do you have a list of the spliced connections and the wiring colors? Not written down anywhere but the wires are marked so i guess i could put it in a script or how-to.
Old Feb 22, 2011 | 11:09 PM
PacerSS's Avatar
Could it be possible to keep the upper dash of the 00-05 and cut it to mate to the radio and lower part of the 06?
Old Feb 22, 2011 | 11:11 PM
Dredd's Avatar
Originally Posted by punisherss
Amazing...would you want to sell me the ash tray setup in the front cupholder there from the old dash? lol
Sure just let me know where to ship it to.
Old Feb 22, 2011 | 11:17 PM
Dredd's Avatar
Could it be possible to keep the upper dash of the 00-05 and cut it to mate to the radio and lower part of the 06? YEP!!
Old Feb 23, 2011 | 09:06 AM
RickAKATed10's Avatar
Photobucket
This is one sweet project. Keep up the good work!
Old Feb 25, 2011 | 10:41 PM
Dredd's Avatar
Great post
Heres the link to a video of DaMonte running http://www.fquick.com/videos/They_sa..._be_done/10138
Old Feb 25, 2011 | 11:02 PM
it can't be done man... that is totally badazz!
