6th Gen ('00-'05): **Car Won’t Shift Into Gear**
Recently was heading onto the freeway and right as I got on the freeway my car just stopped accelerating to the point where I had to pull over and get it towed. There’s no smoke, had a transmission flush around November or so, any suggestions on what the problem may be. It won’t shift into gear at all, starts and operates as normal but will not go into gear, thanks!!
I have had it done as a complete change as well as a flush. So far so good. Some of these rides have a sealed Transmission you can't even check the fluid level.
In the case of the flush I believe the garage who flushed it didn't get enough fluid back into the Transmission and it was ran to long on low fluid.
Something to check
Check the Trans Fluid level while running in Park. If the level is up you would probably be Okay.
starts and operates as normal but will not go into gear ** can you explain this in more detail?
1. As it sits in the driveway running and won't shift out of Park into gear?
Or 2. it is while moving down the Hwy?
The thing that bugs me about how that ad is worded is that they try to spin it that changing the fluid will help in the case of overheating. I dont disagree that overheating is a common cause of trans failure, but a fluid swap will often not permanently solve issues on an already damaged trans nor will it stop the overheating from reoccurring.
What you may want to check is if it starts and runs but won't go it could also be a Catalectic Converter plugged up.
If so, the only 2 other easy things I can think of:
-check the range selector on the trans and make sure its actually moving (ie something isnt broken or bound up)
-has the trans fluid ever been changed? If so, its remotely possible the filter wasn't reinstalled right and fell off (so there's zero fluid being pumped around)
If none of that is it, I'd think it's new trans time also. There isnt much you can fix externally.
