waxing spoiler
I bought a pace car style spoiler for the monte and its mounted but am having trouble getting wax to take on it. Its staying like a matte finish. Is this common? Is it the material of the spoiler?
Did you try washing it first? Im sure..but wash, then dry, then wax. What type of wax are you using? Spray? Or the old fashion with the microfiber towel? And no, I wax my SS spoiler alot when I wash it. Im gonna wax it again as a matter of a fact lol.
Originally Posted by tweek
(Post 579128)
its a remanufactured piece. When I had it painted my painter said he even had some trouble with it. Im thinking its the material. Ill try and claybar it today and see what happens.
Ok to me it sounds like Dried on Wax and you are just waxing over the top of it. It will look flat or satin on that spot .Try 3m adhesive remover or the Goo Gone that is safe for automotive paint. I know they remove the wax from your paint.
Or bug remover for cars
(Post 579133)
Etching primer is a filler, sealer type primer... So, maybe he may have to repaint it to get it to look right? By using "Etching" primer on it before he applys the base coat clear coat? I hope the clay baring does the trick.:thumbsup: |
Im going to clay bar it in a couple of hours.
You should strip the wax and then clay bar it use Dawn or Adam's All Purpose Cleaner to strip the wax. If that doesn't help you might need to color sand it and buff.
(Post 579133)
If your painter is a professional and was having trouble with the paint sticking it sounds to me like: - He did not properly prep the piece (it may have had a "gel coat" that needs sanding to prep for prime and then paint for example or if it was a previously installed part, may need some cleaning and sanding). - The material it's made from is resistant to paint or has a special need situation. As for the "finish", did you painter use base coat/clear coat? If clear, how many coats of clear? And lastly, where did you get the spoiler from? |
