-   Detailing (https://montecarloforum.com/forum/detailing-10/)
-   -   Wax on rubber and plastic (https://montecarloforum.com/forum/detailing-10/wax-rubber-plastic-59925/)
Jeffs02rwdSS Jul 13, 2018 08:27 PM
Wondering what I should use to get wax and polishing compound off of plastic and rubber ? I have tried alcohol on a rag and some bug and wax remover neither did much any suggestions would be great.
The_Maniac Jul 13, 2018 08:52 PM
I usually had good result with Mother's Back-to-Black. Could give that a shot.
drivernumber3 Jul 13, 2018 09:56 PM
If you have some Wesley's tire cleaner try that, get the old one they were bought out. get at the hardware store and not at Walmart. :thumbsup:
JuniorCar Jul 13, 2018 11:21 PM
I use a product called "Kleen-Flo Holistic Rubber Care", but I don't even know if you can get that stuff in the US
SuperchargedMonte Jul 14, 2018 05:18 AM
I am curious did you ever do this with soft rubber around the sunroof? Thanks!
wht02monte Jul 14, 2018 06:13 AM
The things suggested above wont FIX your problem.. Theyll cover it up for a week or so. Plus things like to stick to tire shine like dust and dirt..
The only thing I have had luck with actually removing wax and polish off rubber (like around my rear windows) is buffing it out with a dremel tool.. Even that didnt get it all.
I think the wax absorbs into the rubber or a chemical in the wax reacts to the rubber creating a change in the rubber itself..
The_Maniac Jul 14, 2018 07:23 AM
I've used it on that and other black rubber and plastic pieces. The downside with the sunroof piece, it only darkens a little bit. It does not go full black.
JuniorCar Jul 14, 2018 01:38 PM
Disagree! The Holistic Rubber care stuff I use is not a dressing at all. It's a thin non-gelling product delivered from a aerosol can and if you spray the crap out of rubber with it enough to get it wet it will all absorb right into the rubber. It's a rubber restoration product designed to make rubber more pliable. It's intended to be used on hoses, weatherstripping and CV boots.
I can't see a Dremel not doing damage, even with just a brush bit
SuperchargedMonte Jul 14, 2018 03:05 PM
Thank you!
Suburban73 May 13, 2022 02:12 PM
Try a white rubber eraser you can buy at Staples
