Review: Meguiars Microfiber DA Correction
I picked up Meguiars Microfiber DA Correction kit,
Quoted from autogeeks site
http://www.autogeek.net/da-microfibe...r-kit-5in.html
Link to the 5in starter kit ^
Used it with my new Groit's Garage DA
I had a door panel from a car i parted out i thought it would work grat as a test panel!
Preped by washing with Chemical Guys, Citrus Wash+gloss, concentrated 1oz per gallon to stip any existing waxes and grime,
Claybared with Mothers Clay and No Rinse Wash and Shine as clay lube,
Corection,
Finished wax
Topped with pinnacle liquid souveran,
I am extreemly happy with this it is extreemly user friendly and creates great results! I would buy again and will likely be my go to!
Now for pics
Meguiars DA Microfiber Correction System is a two-step process designed to correct paint without leaving any swirls- guaranteed! Meguiars DA Microfiber Correction System consists of microfiber pads, DA Microfiber Correction Compound, and DA Microfiber Finishing Wax.
Meguiars Microfiber Correction Compound is expertly formulated to remove light to moderate flaws while creating a high gloss. It gets it polishing power from Super-micro abrasives. These tiny abrasives level swirls and scratches without creating new ones. Meguiars Microfiber Correction Compound performs without dusting or slinging, and cleanup is easy.
After using Meguiars DA Microfiber Cutting Compound, Meguiars DA Microfiber Finishing Wax refines the paint even further to create the clearest, most uniform shine. The combination of polymers and carnauba makes Finishing Wax both durable and glossy.
DA Microfiber Discs are available in cutting and finishing discs. Their engineered foam interface offers controlled conformability. The microfiber cutting discs are gentle on the paint and do a fantastic job of evenly distributing DA Microfiber Correction Compound and letting the abrasives do their job. The result is smooth paint with no swirls!
Meguiars DA Microfiber Finishing Discs are made for maximum efficiency. As you move the polisher over the paint, the microfibers adapt to the curves and contours of the paint, distributing the wax and mild cleaners evenly for maximum protection and gloss.
Purchase each part of the Meguiars DA Microfiber Correction System separately or get ready-to-use kits already prepackaged for your convenience.
Meguiars DA Microfiber Correction System revolutionizes defect removal and surface finishing with no swirls - guaranteed!
Corection,
Finished wax
Now for pics
My Meguiars Man! Heck that was quite the transformation on the door panel. I mean a dramatic change. My Monte is crap right now, as it has been waiting for almost 2 months for the mechanical work to begin. It is in dire need of a thorough cleaning and waxing. I love Meguiar's products to. Will look into this and use it when I strip the finish down. And the Pinnacle Vodka topping is cool too! Thanks for the visual.......
i have to say i couldn't belive how nice it was to work with this, easy on easy off, it's a little wierd becuase you use a slower speed than using foam but can say this is a awsome product meguiars hit a home run on this one,
do the 2 steps then finish off with a blue Lake Country ccs flat pad with the pinnacle, i honestly can not wait for warmer weather to spend countless hours cleaning up the pace car!
And thank you autogeek for the free sample of the pinnicle with my order =)
I always use meguiars... I actually did my car, hand waxed with meguiars probably 6 months ago, my cars been through all the salt in WI this winter and a good pressure washing.. still water beading up today like I waxed it yesterday.
