Removing dashboard
Hi everyone,
i plan to order a 3m ''wood effect'' vinyl to put on my dashboard. I would also remove doors side panels to match them with the new vinyl. I am kind of tired of the common grey plastic look in front of me. So here is my question: Does anyone know how to remove the main plastic dashboard located around the radio and that goes all the way around to the left side of the steering wheel? I had a quick look at it, but i was scared to break anything since its the first time i do this. |
Remove the panels under the dash. 1st has clips, and 2nd has 2 screws. Start on the left and pull straight out. Watch things like the 4 way switch, trunk switch, ignition, and pull the facia straight out.
allright thanks alot ill sure follow your steps.
i'll post some pics when i'm done with it:) cheers! |
