-   Detailing (https://montecarloforum.com/forum/detailing-10/)
-   -   hood problem (https://montecarloforum.com/forum/detailing-10/hood-problem-33851/)
bblackstone Jan 30, 2012 06:25 PM
hood problem
I have my primary hood with a problem. A while ago I put on a bow tie. Ran it a day and hated it on. Took it of but left residue that will flat out not come off. Goo gone. Paint thinner. Mineral spirits. Decale remover 3 different kinds. Rubbing compound. Both new and old school. No luck. any other suggestions? Oh I also tryed heat.
The residue is glue and paper like substance.
Boxman420 Jan 30, 2012 07:45 PM
what did you use to put the bowtie on?? should have just used double sided tape.. if all of that didnt help.. your probably SOL and will have to sand it off then repaint it
bblackstone Jan 30, 2012 08:36 PM
big
I guess I should say. It was a 17x36 decal. Huge!!!!!!!!!!!!!!
xxtheshockerxx Jan 30, 2012 11:45 PM
you need to find a good solvent to eat that glue. i cant really tell you anything that is easily accessible because i buy from a chemical distributor. I havent ever had much luck with stuff off the shelves
Jomao_o Jan 30, 2012 11:58 PM
As last resort I would have suggest paint thinner, but you already tried that. :(
Very very fine sanding paper in the areas?
ChibiBlackSheep Jan 31, 2012 08:02 AM
how comfortable are you with wet-sanding?
03SSLE Jan 31, 2012 08:31 AM
WD-40 followed by isopropyl (rubbing) alcohol then polish and wax. ;)
AwesomeSS Jan 31, 2012 08:33 AM
Wet sanding and buffing will take it off.
Mels SS Feb 2, 2012 12:35 PM
I agree with the WD-40
77gp Feb 2, 2012 02:10 PM
When I re-did my 80 Z-28, I went to the paint store and got some decal remover. It would be better quality than something from say Autozone or a common store. It worked well to eat the old glue off from the stripe package. Good luck. I am sure something will get it off. Have you tried a heat gun them Aclohol or Wd-40?
