6th Gen ('00-'05): film
im assuming you're talking about the hazy looking crud or whatever that builds up on the window. I had luck using a clean micro fiber rag and it cleaned up pretty well for me. A lot of people say newspaper works well for cleaning windows.
Stoner's Invisible Glass and microfiber towel. Make sure the car is in the shade and the glass is cool to the touch before cleaning. More than one cleaning may be necessary if the windows have heavy build up.
x2, and a plush NICE microfiber. Not those thin cheap things that you purchase from auto parts stores or walmart. And you will be sitting there wiping the window for a long time to make sure you get ALL of the cleaner and debris off.
since i smoke my rear window is a nightmare with the the haze. and tints
i have been using hot water mixed with 20% rubbing alcohol
soak it on the window the more the better
DONT DO THIS IN THE CAR WITHOUT VENTILATION
if its not tinted use newspaper
if its tinted just rub it with some microfiber towels
also heard white vinegar is good but smells
