Widest Tire on 20 X 8.5
What is the widest tire you can put on a 20 X 8.5? I have 255's on it right now, and have been told that is the widest I can go with my wheels. But I just don't have enough meat in the back, and need to go as wide as possible. I have too much HP for 255's and there is nobody making a Drag Radial for 20's.
RE: Widest Tire on 20 X 8.5
thought you had some one to reply tha tgavea link to the drag radials ? did they not work for ya?
Also i have 225 60 r16 on mine and belive me it is under 20" round and less then 8.5 wide at the rim.
we used to mount 50's on a 8 " wide wheel .
so i would get a second opnion on this one.
ORIGINAL: mickey
So now I'm just trying to go as wide as possible, but I'm stuck with my 8.5 wheels.
im guessing you could go wider, if you went taller. with as short of sidewalls as you have im guessing theres only a couple choices of widths that would work. anything stickier in your current size? what tires and size are u running now? 255-??-20 ?
they look like 30's or 35's on there for the sidewall....can you fit a 45 on there??? because they probably make them for 45's as they're the most common sidewall you can get for 20's
if you chose to do that you could go with a lowering spring in the front or air shocks in the tail (how all the kids do it)
sorry to hear that you are coming to this conclusion.
you know the bad thing is with all of them coming out now I'm really surprised they don't have what your looking for in that size.
but the min. you sell then they will have them everywhere on the market.
2nd Gen ('73-'77): Widest tire on 73 MOnte rear 17x9
GWShark
12-29-2014 04:20 PM
LoudBlazer
11-24-2009 12:23 AM
