new wheels an tires - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 11-26-2009, 09:47 AM
OD_85'305_SS's Avatar
Cool new wheels an tires
does anybody know whats the biggest wheel and tire combo i can fit under my 85 monte ss
i kinda want to put c4 wheels on it .......would they work bolt pattern wise ?
also if anybody knows if the wheels off the mid 90's impalas would work/fit?
or if anybody has any 86 and up ss wheels they want to get rid of
or some i-roc wheels
please let me know
Old 11-26-2009, 10:47 AM
Budsjlm's Avatar
bolt patern from corvette,malibu,monte,elcomino,firebird,camaro, are all 5x4.75 the c4 rims will work but you will more than likly need spacers for the rear so it will not rub
Old 11-26-2009, 03:11 PM
TheMonteMan's Avatar
i dont think a setup like that would work. i think all of the vettes ran real deep backspacing and depending on how fat of a tire you want to run your probably going to rub on the inside near the frame. i dont know what kinda diameter your looking to run but on a 15x8" rim the widest ive fit without rubbing was 275/60/15s with 3.75 or 4in backspacing either will work. your lookin at 28in tall overall diameter and about 11in wide at the buldge. if you stay within those dimensions and keep the backspacing in the 3.75 to 4in range u should be able to fit a ton of wheel tire combos.
Old 12-02-2009, 05:58 PM
LT1 Monte's Avatar
Location: Colocated I work and live in Montgomery AL working for Air Force and have a house with my toys in TN
Quote:
I was hoping to run 275/50/15's but from your experience it sounds like that will hit. I wanted to have some serious meat, but I can simply use a set of slicks at track...
Glad to have read you post probably saved me some real grief. The slicks I have are I think 8" wide and 26" tall so I think they will fit with no problems.
Thanks
Old 12-11-2009, 05:55 PM
ive tried 275 50 but that was on a 8.5 with 3.5 backspacing. it was a hoosier quicktime tire and it rubbed if i had weight in the rear. i trimmed the rear wells and they would still rub on the quarters but that car had a sloppy spring and shock set up. if it would have had 8" wheels on it it would have fit. heres the pick of the car with the old wheels they were 15x8 with 3.75 with 275/60/15. the new set up has 3.50 neither rub i perfer the 3.75 just think it makes the wheel look fatter. i like running the 28" tire cause with the 3.73s and the 700 first gear and the torque of the 406 its tough to get off the line so a little bit of tire helps kill the gearing a little. and when i had the 350 trans with no motor work it was a nightmare with a short tire.
Reply
Thread Thread Starter Forum Replies Last Post
Help with new wheels and tires wutwut25 Tires/Rims/Suspension 18 01-25-2013 10:24 AM
Getting new wheels n tires from tire rack... Tpms? jeffsmonte Tires/Rims/Suspension 8 10-15-2011 02:43 PM
New Wheels & Tires 03SSLE Tires/Rims/Suspension 26 09-30-2011 09:11 PM
New wheels and tires on the Suburban Teacher Off Topic 12 03-28-2010 05:54 PM
Tags
86, backspacing, biggest, carlo, fit, largest, monte, put, rear, rims, ss, tires, wheel, wheels, widest
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
