Monte vibrates-shakes when I accelerate. Please HELP!!! - Page 2 - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 12-28-2011, 11:10 PM
01 Monte SS's Avatar
I have the same problem however only while accelerating and turning right. While turning left or going straight there is no vibrating/shaking? Do you think I'm having the same problem I'm pretty sure it's not the bearing.
Old 12-29-2011, 02:25 AM
Yes it could be the axle because it puts a strain on it when you turn.
Old 01-01-2012, 04:59 PM
Default From what I've learned as an Apprentice
From what I've learned @ Hyundai the wheels could be out of balance. Usually a vibration above and between 70-100km/h and steering wheel shake from left to right. Usually a bad tire or a bent wheel could cause a really bad shimmy. I don't know if you guys have access to a balancer but when I mount and balance wheels at work I look directly at the tire to see if there is a wobble in the tire. You'd be surprised how many wheels I've balanced with a wobbly tire and asking for more than 2.5oz weights on 1 side. To diagnose a vibration I'd have the wheels rebalanced after doing a thorough inspection of steering, suspension, & driveshaft components. The next step would be to have the wheels rebalanced. Don't be shy to ask the tech that is balancing your wheels how much they were out and if he/she can put the wheel with more weights in the back that way the shimmy isn't as noticeable. Also, I heard a Hunter Roadforce Balancer is a good machine to balance aftermarket wheels and apparantly its really accurate (about .05 or .10 oz.) When checking wheel bearings raise the wheel off the ground, shake the wheel 12 and 6 oclock and listen for a clicking clunky sound/feeling. From what I've learned from the other Tech's checking inspecting a CV joint (assuming the boots arent torn and moisture hasnt entered the joint) raise the front end and put the car in drive, inspect the CV for play or an off axis rotation (if CV's are the culprit I recommend buying a NEW axle from GM even though its like $600 a piece, I wouldnt settle for an aftermarket Reman). Also inspect motor mounts/bushings/tranny mounts/subframe bushings for looseness or cracking (I Believe that will contribute to a vibration.) Certain steering components/linkages or even a damaged frame can cause a vibration.
For those doing the inspection themselves, raise the car and check everything. Thats where I'd start and than work your way towards the wheels,bearing/axle. I'm open to any input or advice if what I wrote isn't correct.
Old 01-01-2012, 09:30 PM
Ashley.Marie's Avatar
Mine did the same thing, just had to fix it last week, axle and tie rod end, I get a deal on parts and labor at the dealership, cost me 300 for all that and an alignment.
Old 03-02-2012, 03:54 AM
CIN Vicious's Avatar
Wow, mine just started doing this craziness. It handles just as u mentioned...when cruising no pulsing, but when accelerating there's a pulsing sensation...when hittin corners, especially right corners, there's a feeling that I can't describe, but I know it isn't natural, almost as if something is loose or damaged in the suspension somewhere in the front. Hopefully its just the axles that need replacing, and from how u mentioned your issue with yours, it sounds like the same issue, exactly; either way, gotta get my baby riding right again.
Old 03-03-2012, 09:45 PM
i have the same problem and I am positive its the axles too. I have been driving on it for a few months lol, but I am gonna throw new axles on third weekend of March
Old 03-04-2012, 05:11 PM
put in a new cv shaft and that should take care of it. thats what i did and it runs like a champ now
Reply
Thread Thread Starter Forum Replies Last Post
5th Gen ('95-'99): 99 Monte LS vibrates at different intensities whenever stopped and in gear. dankind38 Monte Carlo Repair Help 2 01-21-2014 11:49 AM
Car shakes at speeds under 60mph, and when turning right. Help please. gamblehouse2003 Monte Carlo Repair Help 16 03-11-2012 12:24 PM
2000 Monte Carlo SS idles wont accelerate powerguy5051 Monte Carlo Repair Help 10 02-24-2012 07:56 PM
01 ss wont accelerate corrado1979 Monte Carlo Repair Help 12 10-05-2009 02:22 PM
Tie rod ends (Shakes, vibrates) mksiler Monte Carlo Repair Help 0 03-24-2009 08:55 PM
Tags
00, 2004, accelerate, accelerated, accelerating, axel, car, carlo, chevelle, cv, end, front, gas, give, monte, montecarlo, shakes, shaking, ss, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
