02 monte rear wheel bearing assembly issue
I’m new to the forum. I have done some searching and haven’t found any help yet. I have a 02 monte ls. The rear wheel bearing went bad on it. The speed sensor gave me troubles. I changed it. I removed the spindle assembly. Pressed out the bearing assembly then put it all back together. The car had a shimmy to it. I drove it that way for 2 years. Put another bearing assembly on it. Figured I had a bad manufactured assembly. Still have a shimmy to the cars ride. Any thoughts to why it shimmys?
Sounds like a bad tire to me. Might just need balancing. Another thing it could be, how did you torque the lug nuts? By hand with a torque wrench set to 100 lbs, right? These cars are REAL sensative to mis-mounted wheels. I've had several brake rotors messed up from that.
My 1st guess is a bad tire or a wheel out of balance.
