gas gauge fluctuates
Old Jul 15, 2010 | 08:26 AM
BoNeSaW's Avatar
Default gas gauge fluctuates
my gas gauge fluctuates when it reaches about 1/4 tank or so.... only when car is on. As I drive will show 1/4 tank, then it moves up to 1/2 tank or 3/4, when i shut car off it returns to the normal position. When the tank is full or half at least, it always stays put..... could this just be a sensor issue? easy fix? It's a 99 Z34
Old Jul 15, 2010 | 08:51 AM
I think this is normal. GM tanks tend to be top heavy so it will move around a little more when its below 1/2.
Old Jul 15, 2010 | 08:53 AM
terryloveless's Avatar
I started having the same characteristics. I'm assuming a fuel sender replacement in the near future
Old Jul 15, 2010 | 09:27 AM
MAMONTE's Avatar
You need a new sending until. If I was you, i'd repalce the whole fuel pump and sending unit all at the sametime.
Old Jul 15, 2010 | 02:48 PM
PacerSS's Avatar
Yup that was the first stage of my sending unit problem. At first it does that. then it will read a half tank then it goes to straight full all the time and doesn't work at all. Which is where mine is at. Been to lazy to replace it so I just do the mileage calculation. When I get back and I do my top swap build I'll pull it out. But you should start looking into it now. Everyone else in this thread is absolutely correct.
Old Jul 15, 2010 | 02:53 PM
Mac7504's Avatar
Everyones correct, (fuel sender unit) had this same exact issue but replaced under warranty, luckily.
Good luck man.
Old Jul 15, 2010 | 08:40 PM
Krone89's Avatar
I had the same issue and all I did was bend the small metal contact resistor arms a little bit. It wasn't quite touching the resistor so I wasn't getting a good reading. Problem solved
Old Jul 15, 2010 | 08:54 PM
silverstreak's Avatar
bending the arms a bit do you have to pull the whole pump and drop the tank or can you go through the trunk???
Old Jul 15, 2010 | 11:21 PM
1984SuperSport's Avatar
our 03 Cavalier LS SPORT does the same thing but its not enuf to bother me
Old Jul 16, 2010 | 05:59 AM
PacerSS's Avatar
There is an access panel located in the trunk. A few screws and viola you're pump is in your hands.
