high flow injectors
Old Feb 19, 2006 | 11:58 PM
maclawa's Avatar
Default high flow injectors
hello I am in the process of s/cing my L36 engine up to 300 hps and I am wondering why should I upgrade my injectors if they're good up to 300 whp?
this is off of the zzp website where they state that....
thanks
Old Feb 20, 2006 | 12:01 AM
The Black Machine 29's Avatar
Default RE: high flow injectors
why take the risk? it will be good to replace them anyway
Old Feb 20, 2006 | 12:03 AM
maclawa's Avatar
what am I risking in not replacing them? its an 02 monte ss as well. I was going to get them until i saw that note on zzp. still need fuel rail throttle body and injectors then I should be good to go.
Old Feb 20, 2006 | 12:07 AM
if your trying to get to 300 and your injectors are good to 300
dont ya think thats a little to close for comfort?
maclawa's Avatar
good point haha
Old Feb 20, 2006 | 12:08 AM
lol yeh.. what have you done to your monte so far anyways?
Old Feb 20, 2006 | 12:12 AM
maclawa's Avatar
well just the intake to date..... before my sc goes in... I'll be deleting ubend, larger downpipe, high flow cat, and better mufflers, you know the cheap stuff at the back before the expensive stuff at the front. I have an m90 supercharger which I'll be replacing the couplings, and I have L67 heads too. need fuel rail, injectors and throttle body off of the L67's. and then I do my ecm modifications and my compression ratio too, bleh. oh well its good times.
Old Feb 20, 2006 | 12:13 AM
maclawa's Avatar
also put on custom headlight covers which are same color as the car and LED tail lights plus doing some interior stuff to it soon and new hood as well plus SLP front grille I've saw..... its al a project right.
sounds good.. what year is it?
so far mine is stock except for rims and system...
im going to get intake exhaust and all that in the summer
Old Feb 20, 2006 | 12:15 AM
maclawa's Avatar
02 monte ss, it has the limited edition ground effects which I'm going to paint red to spice it up. whats the system you have in it? I was going to change the amp and put subs in it..... dont know if I can though due to the computer crap in the stock cd player unit
