Red gauge lights
RE: Red gauge lights
Hi Matt
Super Looking Mod
How difficult would it be for other members to do it ?
Please take more pic's
Thanks for being a active contributing member
during these difficult posting times on the MCF
Wish you and the reader of this post a Happy
Step 1: Order 5 194 socket red LED lights. The "tower" style with lights on the sides and top.
Step 2: Remove the two philips head screws that hold the filler panel below the steering wheel on. Let it hang down out of the way
Step 3: Pull off the plastic panel from around the gauges and radio. It is just held on by clips. It may be hard to remove the first time, but just pull on it, it wont break. Keep track of the metal clips that hold it on because they want to fall off and go down into the dash.
Step 4: Remove the two 7mm bolts that hold the gauges in. Lift up and tilt the bottom out first and slide the gauges out.
Step 5: Remove the 5 sockets that hold the lights. They are grey and twist out. 3 on speedo, 1 on tach and 1 on gas/temp gauges. Replace with the LED lights. Make sure they all work before you reinstall everything or you will have to pull it all back out.
Reinstall everything in the opposite manner and you are done.
