brakes are alittle funky
Old 01-23-2013, 01:42 PM
tps221's Avatar
Default brakes are alittle funky
thy stop fine and theres no grinding but it feels like theres alot of deadzone and then not much extra play once it starts to stop compared to slamming them. my front rotors and pads are a year and a half old i dont know if the drums in back need service maybe?? i just want to avoid issues and mechanic had it up in the air to fix the exhaust heat shield (what mad it sound louder he just bent it back). he didn't notice anything with them maybe its just me
Old 01-23-2013, 01:57 PM
You might need to get the fluid flushed or bled
Old 01-23-2013, 01:58 PM
tps221's Avatar
think it can wait til spring break?
Old 01-23-2013, 02:12 PM
You said they worked fine :p
Old 01-23-2013, 02:17 PM
tps221's Avatar
they do its just alot more pushing down before they work and less to lock them up
Old 01-23-2013, 02:30 PM
If you are comfortable to drive, then it can wait. At least check the fluid though, make sure you aren't low
Old 01-23-2013, 02:41 PM
tps221's Avatar
i did and it seemed fine any tips on checking brake fluid
Old 01-23-2013, 04:50 PM
mine doe the same thing, alot of travel in the pedal before you actually apply the brakes. I know im in need of rear brakes soon so i'd assume worn brakes are the cause for me.
Old 01-23-2013, 05:26 PM
Expect the brake fluid reservoir to be a little low if the brakes are worn. Should you top it off now and then later when installing new pads compress the wheel cylinder, the now excess fluid will be forced to overflow out from underneath the reservoir cap making a fair amount of a mess to clean up. Brake fluid does not do any good on painted surfaces and all over the frame etc. . If the reservoir seems excessively low then fill it to perhaps about 3/4 full.
Old 01-23-2013, 07:40 PM
Since you mentioned it takes a good bit of pedal(pressure) to get it to start to stop..
Not to mention its been a year and half..since your last maintenance....
Ever considered they might be glazed over?
Glazed over brakes require an excessive amount of brake pressure to get the vehicle to stop.
Example:
Drag raceing...
Driveing 2 footed...(dragging the brakes)
Hard launch and stops? (in traffic)
Racing from one stop sign to the next etc etc...
Just a thought..
Quick Reply: brakes are alittle funky
