monte carlo gear is stuck in parking
Old 01-26-2015, 09:02 AM
mentada404's Avatar
Awaiting Email Confirmation
Default monte carlo gear is stuck in parking
My 2000 Monte Carlo is gear is stuck while pack.
Old 01-26-2015, 09:04 AM
mentada404's Avatar
My 2000 Monte Carlo gear is stuck while pack in packing lot. What is the solution or part needed?
Old 01-26-2015, 03:11 PM
Its a good possibility..
In the console by the shifter mechanism.. Theres a shifter solenoid...
The way its designed/setup... Theres a good possibility like many others have had this issue... Is a cracked/broken wire.
You have to take the console partially apart to get to it..Then you can release it manually until you can reconnect/resodier the wire back in place/together.
Heres a link and what to look for/Pics!
https://montecarloforum.com/forum/mo...k-42752/page2/ <------- Clicky
Old 01-26-2015, 05:58 PM
ohara's Avatar
Welcome to the forum, David gave you some pretty good directions on how to go with fixing your car. Best of luck
Old 01-26-2015, 06:18 PM
Did the shifter solenoid replace the neutral safety switch or is there still a neutral safety switch in the newer cars?
turbo monte
04-04-2013 10:01 AM
ABLOND
10-27-2012 04:04 PM
RIMONTESS
04-14-2011 07:47 PM
slinkeey
12-08-2009 07:54 PM
81Monte350Power
01-05-2008 10:00 PM
Quick Reply: monte carlo gear is stuck in parking
