4th Gen ('81-'88): car shutting off......
Old 12-26-2012, 09:43 AM
mrbigs's Avatar
Default car shutting off......
I HAVE A 1987 CHEVY MONTE CARLO LS. RECENTLY IT CUTS OFF WHEN I TURN A CORNER AND WHEN I BACK UP TO PARK. IT DOES NOT SHOW ANY TROUBLE CODES. I CHANGE THE SPARK PLUGS AND CHECKED THE VACCUMS HOSES. WHEN I,M ON THE HIGHWAY,IT DOESN'T SHUT OFF.HAS SOMEBODY HAS THIS PROBLEM BEFORE............
Old 12-26-2012, 02:27 PM
Budsjlm's Avatar
Check your lead going from the alt to batery, my old blazer had this kind of issue ended up being a bad conection between the two
Old 12-26-2012, 10:50 PM
mrbigs's Avatar
What year was your blazer?
Old 12-26-2012, 11:06 PM
Budsjlm's Avatar
89 it was a s10 blazer 2.8 v6 but had the same kind of deal dying randomly, which in a sence is wierd becuase it should run off the bat for a while but mine just died, random bumps, turns ect would triger it
Old 12-26-2012, 11:09 PM
Budsjlm's Avatar
Also might want to check the conections at the starter, there should be 3 conections on it, the battery, start and run, the run wire might be loose or coroded, also check any grounds a lose/corroded ground can cause funky issues too!
Helmittt
08-01-2013 08:24 AM
mrbigs
02-03-2013 11:42 AM
benh911f
06-19-2011 03:26 PM
llooney18
12-29-2010 01:26 PM
Nathan79
12-04-2006 11:06 PM
Quick Reply: 4th Gen ('81-'88): car shutting off......
