window came off track!!! - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 10-22-2007, 02:14 AM
Default window came off track!!!
so my 98 z34 monte carlos driver side window rolls up, but when it gets to the top it gets pushed outside the molding and is off its track, i have to force it into place! i took off the door panel and i coudlnt' get to the window is there anything else i can do or is it just worth taking it in to get it fixed?
Old 10-25-2007, 10:33 AM
Default RE: window came off track!!!
I'll ask my buddy in a couple hours for you, he is an auto glass man, just give me sometime.
Old 10-25-2007, 07:02 PM
Photobucket
my 97 has the same exact problem, what has happened is that the metal track has plastic inserts that slide inside the track to make the window operate properly, the one on the front side has worn out i dont know if you can replace that 1 thing but a after market track is only 100 bucks and is simple to replace. my vote is to replace it all and dont bother with the hassle of trying to make what you have work
Old 01-24-2008, 01:19 PM
for anyone in the future who runs into this thread...I did a little DIY that might help.
(granted, it's for a 2004 Monte...but hopefully the concepts are the same)
http://www.montecarloforum.com/m_74316/tm.htm
Old 03-07-2010, 07:30 PM
Zmonte34's Avatar
my 96 did the same thing on both sides, but the spot welds had broken so i just welded them bak up and no problems since
Old 07-21-2010, 01:37 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
On my 98 LS, when I would roll up the window, when it almost got the top, the front of the window fell forward, and had a VERY hard time getting to the top (stayed in track though). Took off the door panel...nothing was wrong, just a worn out track. So, I re greased all window tracks, both sides, and they go up and down perfectly. The driver's side still falls a little, but pick up and keeps going. So, a tip...if your windows roll up and down slowly, just grease the hell out of the tracks...you'll see a difference!
Old 09-21-2010, 10:12 PM
yeah my window did it too, i seen the kits for only $100, so it would be a good investment. it was a real pain when i took the door panel off and had to put the window up since the motor burnt up trying to roll up all the time.
Old 10-23-2010, 10:40 PM
i had the same problem. while the regulator is a simple job, the rivets are a pain in the ***, i broke the drill bit trying to get them out
Old 10-20-2011, 05:25 PM
my window hasnt come off track but it seem like its wobbly-ling back and forth, its really obvious when you roll it down about half way and get up to like 50mph, should i be looking at replacing the tracks?
Old 10-21-2011, 09:33 AM
Please try not to bring back such OLD threads.
Also there's a good chance that a simple bolt has fallen out, or has come loose. I had to take my door panels off and retighten the bolts a few times.
Reply
Thread Thread Starter Forum Replies Last Post
Service Traction Light and ABS and Traction off Lights came on. WHY?? Chris s Monte Carlo Repair Help 16 01-27-2013 05:30 PM
6th Gen ('00-'05): Window came off track DRuben General Monte Carlo Talk 0 04-22-2012 05:47 PM
window loose comes off track kennyjohn Monte Carlo Repair Help 9 06-15-2009 05:10 PM
window came off track!!! ltrain925 General Monte Carlo Talk 2 10-22-2007 02:26 AM
03 rearview mirror came off windshield??? VinceF99 Monte Carlo Repair Help 8 09-22-2007 12:37 PM
Tags
04, 2000, 2004, automobile, carlo, chevy, diy, fix, glassman, home, monte, slide, sticking, track, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
