6th Gen ('00-'05): Will turn over but not start
Have a 2000 ss..engine will turn over but not start..3 times while driving it just died, shifter to neutral and it started right back up...last time I made it home and now it won't restart..replaced fuel pump, but not sure where to go from here...any help?..
First of all - are there any check engine codes? If not...
Unplug the MAF sensor and try to start it. If it starts, there's the problem most likely. If still no start, plug the MAF back in and check for fuel pressure. If fuel pressure is good, then it is (probably) the crank sensor, ignition control module, or possibly ignition switch.
If it doesn't even try to turn over, that's either a starter issue or passlock issue.
Just my .02
Just my .02
schoentges16
02-27-2021 06:43 AM
BrandonStebing
07-25-2014 11:03 AM
z34phoenix
03-10-2014 11:32 AM
jbartram
04-09-2012 03:41 PM
