where is oxygen sensor on 02 monte
Old 11-23-2010, 03:49 PM
goingforgold's Avatar
Default where is oxygen sensor on 02 monte
can someone tell me where the bank 1 sensor located on a 2002 monte and how to replace it
Old 11-23-2010, 10:52 PM
nitehawkjcb's Avatar
Bank 1 is probably the O2 sensor that's on your rear exhaust manifold. You're gonna need a 1" wrench (I believe it's 1"). And something to lube it up with probably.
The other O2 sensor is on your exhaust. Just look at the pipe under the car (around the cat, resonator) you can't miss it.
Old 11-24-2010, 07:43 AM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
Are you throwing a P0420 code? If so, have your cat converter checked first.
Old 11-24-2010, 08:03 AM
I would recommend using the special O2 socket to remove it (unless the location does not permit fitting one in). And hitting it a couple of times with PB Blaster (or your favorite penetrating spray) may not be a bad idea either.
When putting the new one on, if it does not already come with some anti-seize (I've seen some that do), I would dab a little on the threads.
Old 11-24-2010, 11:38 AM
Remove dog-bones, and rock the engine forward a little, you'll see it popping out of the rear exhaust manifold.
Old 11-29-2010, 07:59 PM
Thanks the code said bank one sensor. Is there any tricks as to unplugging the sensor? I think that I located it between the fire wall and rear of engine
Old 11-29-2010, 08:33 PM
Unplugging it is easy. There's a pigtail above the sensor that just unclips. Now getting the sensor out... You need like a 1" wrench and lube.
Old 11-29-2010, 09:46 PM
dustybird3's Avatar
Photobucket
The only reason I asked was because Advance told me that was what the code meant but it wasn't. Had I went with what they said before checking I would have bought it for nothing. A lot of the 2001-2002 models had bad cats that could be replaced free under a "special policy", mine was one of them. There's info here on the forum somewhere, that's how I found out about it. They extended the coverage to 8 years instead of 6 (I think), can't remember the mileage but more than 108,000 because that's what mine had. A sensor would be A LOT cheaper than a cat. Good luck.
Old 11-30-2010, 11:17 AM
I had the cat replaced at 97000 and now I have 148000. The code was P0135
KWJR86
07-12-2021 12:31 PM
kweef
07-20-2008 08:27 PM
splendidkiller
06-04-2008 12:47 PM
04 Intimidator
09-18-2007 07:06 PM
sporges
03-25-2005 12:29 AM
Quick Reply: where is oxygen sensor on 02 monte
