Where is the driver's side vent's blend door actuator - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 06-29-2010, 11:03 AM
Question Where is the driver's side vent's blend door actuator
Hello i've been trying fix my problem for a few days now. I have an 2002 ss and my air condition is ice cold only on the passenger side for some reason the drivers side just stopped getting cold. I had my freon levels checked and was in the proper level. I was told by several people in a previous post that my problem was the actuater or door could be stuck. So i finally found the actuator and spent hours taking it off to realize that was for the passenger side vents only. I did manage to get it back on and close everything back up. But now i need help getting to the driver side actuater i think i touched it on the driver side but it seem pretty high up there burried above some wires. How do you get to it? If thats it.
Reply
Thread Thread Starter Forum Replies Last Post
6th Gen ('00-'05): Driver side blows warmer air then passenger..NOT AN ACTUATOR PROBLEM Blakejake33 Monte Carlo Repair Help 2 08-27-2015 07:01 AM
6th Gen ('00-'05): Driver side blend door Henderson21 Monte Carlo Repair Help 6 07-09-2015 08:25 PM
05 S-Charged blend door actuator Supercharged SS Monte Monte Carlo Repair Help 16 05-20-2012 01:05 AM
2006 Monte Carlo Blend Door Actuator Single Climate grizzlyaddams Monte Carlo Repair Help 3 01-12-2012 10:56 PM
Tags
2002, ac, accuator, actuator, air, belnder, blend, carlo, door, driver, location, monte, side, temp, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
