What should normal coolant temp be
Old 04-04-2007, 05:00 AM
TrapShooter8's Avatar
Default What should normal coolant temp be
What should the normal coolant temp be running on a 05 Monte with the 3.4 V6?
mine is running at about 200 right in the middle of the gauge, is that the normal range?
Thanks, Mike.
Old 04-04-2007, 09:35 AM
Default RE: What should normal coolant temp be
My 00 LS 3.4 and my 06SS 5.3 run normal about there middle on the guage. That sounds about right with the 195 T stat.
Old 04-04-2007, 10:28 AM
wiz kidd's Avatar
yah your fine, the t-stat should be a 195 in there...and most cars i've driven unless they have a 180 in them sit around the middle of the guage
Old 04-04-2007, 01:49 PM
Thanks,
I thought it was normal, but on most of the recent vehicles I have owned the temp gauge stays alot closer to the low end of the gauge, not in the middle.
Mike.
Old 04-04-2007, 02:45 PM
GrandPaDave's Avatar
ORIGINAL: TrapShooter8
Thanks,
Mike.
I used to build meters and guages and I can confidently say that the poor quality of meter installed on today's cars is probably hovering around a 5% margin of error.
I wouldn't be surprised if it was even 7-10% error.
Old 04-04-2007, 10:24 PM
I wouldn't worry about it then... Once it hits 210-220, then swap the T-Stat. If that doesn't do it, start worrying.
ecosta221
08-21-2020 10:35 AM
michelob
06-28-2015 10:25 AM
mrjaysc
10-10-2013 11:17 AM
ecosta221
07-05-2013 10:44 AM
Leprechaun93
08-17-2011 12:06 AM
Quick Reply: What should normal coolant temp be
