7th Gen ('06-'07): What is the cost at dealer for Headlight Replacement for 2006 Monte Carlo?
Old 01-28-2017, 03:12 PM
carenthusiast's Avatar
Default What is the cost at dealer for Headlight Replacement for 2006 Monte Carlo?
Need to replace headlight for 2006 Monte Carlo at dealer. What is the usual cost? Actually, not the whole headlight, just the replacement bulb.
Old 01-29-2017, 10:27 PM
I would recommend contacting the dealer. That is going to be your best chance at getting an accurate price (otherwise, most of us would be ball parking the price).
If you only need the bulb, walk into any autoparts store. Odds are they will have a replacement bulb you can buy off the shelf.
Old 01-29-2017, 10:51 PM
Is this one of those questions being asked because you already paid for one at the dealership? You get hosed? I would ball park at a dealership your probably going to be out $50 to $75 for a bulb, parts & labor.
A parts store perhaps about $15
Old 01-31-2017, 05:08 AM
The LAST place to go for having a headlight bulb replaced?
DEALER
Just go buy a new bulb someplace.
Take the bulb and stand next to your car out in the parking lot.
As others arrive to get some (sheet) they need, ... say "Hi" ... then say:
"Hey. I'll give you 10-Bucks if you put this headlight bulb in for me!"
Over / Under Bets
How many people you'll need to ask: (5 People)
I'll bet two dimes on the Under.
How long the whole thing will take: (45 Minutes)
How long it would take my mother using Finger Nail Clippers or Car Keys: (20 Minutes)
I'll bet two dimes on the Over!
Just because once you pop the hood, ... she's goin'-to-be-all-like: "Let's check the oil and fluids! When's the last time you changed the air filter? You need washer fluid! These stock Plug Wires are crap!"
Old 01-31-2017, 07:19 AM
DEALER
Over / Under Bets
Now here people is a member with an awesome sense of humor. This has to be one of the funniest posts I have read on the forum in a while.
And the nice thing about it is the whole post makes sense and is true. Most strangers given the opportunity, usually love to show off their mechanical skillzzz. Just pay attention on how they did it, as the next time you may be the one making $10 in the parking lot.
Old 01-31-2017, 07:34 AM
I would do it for free
Old 01-31-2017, 09:23 PM
There you go that is the spirit, I like your attitude!
Old 02-01-2017, 11:25 AM
H11 bulb, roughly $12 at any auto parts store. It should take 5 minutes to change one bulb.
On the headlight assembly, unfasten the screw at the fender then pull up/out the white clip behind the round amber blinker bulb - pull the headlight assembly forward and out - pull off the rubber cap on the back - turn the bulb so tabs align with slots and pull bulb out of the assembly - undo the wiring harness from the bulb - install new bulb onto wiring harness and repeat the process backwards.
I would recommend buying a pair of bulbs, which honestly isn't that much more than a single bulb, and replacing that bulb in both headlights so one isn't brighter than the other.
Old 02-02-2017, 08:56 AM
Monte Of The Month -- May 2015
Monte Of The Month -- March 2017
Smile
Here is a video you can watch on it. No your an expert too.
Just google it and Waa Laa!! Hope this helps.
https://www.youtube.com/watch?v=47MA0sSgL50
Old 02-02-2017, 10:23 AM
Pretty sure it's a weird bolt though, I want to say it's a Torx bit, so you'll need to make sure you have a set of torx.
Also, highly recommended to wear gloves when touching bulbs, at the very least use a napkit. Oils can transfer from hands and create hot spots.
