weird lighter problem
Old 06-30-2009, 11:05 AM
skylark65's Avatar
Lightbulb weird lighter problem
ok, my 97 ls has the buckets / console setup, with the ciggie lighter in the console.
i was going to use the outlet for my radar detector, pluged it in, and nothing happened. so i tried my cellphone charger... nothing. i know the radar detector works, i used it in my moms truck.
heres the strange part: even though accessorie plugs dont work, the lighter itself does!
im at a loss because i really want to use my radar detector, and obviously if the lighter works it cant be a fuse. or can it?
does anyone have any ideas on what this might be?
thanks!
Old 06-30-2009, 11:17 AM
there are 3 different sizes of cigarette lighters, are you sure you are equipped with the appropriate one to run that kind of device?
Old 06-30-2009, 11:27 AM
Hi `Ryan,
The lighter works & the accessories plugs don't
Are the contacts for your accesories different at their
base then your lighter ?
Can you try your accessories in another vehicles lighter socket ?
If they work on another vehicle then you know that you
socket is bad for your accessories in your Monte &
may have to be replaced.
When you push your lighter in on your Monte, does it
pop out by itself ?
What was I talk'in about...? I'm lost...
Hopefully a member that knows something about this will
post a solution.... I'm just filling in the empty space on
this page, and wanted 2 wish U & Member's reading
this far a `Happy : )
Old 06-30-2009, 11:42 AM
skylark65's Avatar
ok, that makes sense, i guess my socket does not have enuff juce to run them, or the contact points are wrong. does anyone know of a vehicle that would have a better socket i could grab in a junkyard? and would it fit my car?
Old 06-30-2009, 11:55 AM
Hi Ryan, below is your reading assignment for 2 Day What ? Do I have 2 No, but knowledge is Power : ) Hope U Find what U need
Custom Imprinted Auto adapter. Power adapter plugs into cigarette ...
Auto adapter. Power adapter plugs into cigarette lighter socket. Great for charging iPod (TM), MP3 players, Blackberry (TM) or other USB charged devices. ...
www.promopeddler.com/.../auto-adapter-power-adapter-plugs-cigarette-lighter-qqp457043.htm - Cached - Similar
Cigarette Lighter Sockets
Show all 3 Pages with hits for cigarette lighter sockets by Auto Krafters, Inc. ... cigarette lighter sockets in Galaxie and other Full-Size Ford Parts ...
www.who-sells-it.com/r/cigarette-lighter-sockets.html - Cached - Similar
dc cigarette lighter socket - Products for dc cigarette lighter ...
Power source: 12-24V DC cigarette lighter socket Dimensions: 88mm x 54mm x 22mm (L ... DC adapter Car cigarette lighter Plastic material: ABS Product size: 21 x 9.5 x ... Set for charge Special Power Adapter Auto Cigarette Lighter Set . ...
www.ec21.com/ec-market/dc_cigarette_lighter_socket.html - Cached - Similar
Old 06-30-2009, 12:54 PM
Enzo354's Avatar
STILL SLOW
Just hit up a local napa or autozone, theyre like $5 new.
Old 06-30-2009, 02:44 PM
Budsjlm's Avatar
had that issue in my 85 just had to wiggle it till it worked my just be a dirty contact cuz the accesory has smaller contact area than the lighter iself
Old 06-30-2009, 02:50 PM
skylark65's Avatar
imma have to try that, bud.
just went out and tried your advice, bud. it worked! thanks for the help, i cant beleive i couldint think of something that simple, lol.
Old 06-30-2009, 03:01 PM
Budsjlm's Avatar
carefull tho it might **** ya off mine used to go on a off real quick when i hit bumps.... sound sequence when it turned on got old fast
Old 06-30-2009, 03:05 PM
skylark65's Avatar
yha, i think mines gonna wind up doin that too... i guess the sockets loose or something. maby if i use somekind of shim around the plug...
Quick Reply: weird lighter problem
