Power Steering Problem
3.4 V-6 72,000 mi
Every morning I start my car, I hear a loud whining sound for about 5 seconds (car in garage), which I have found out is the power steering pump. Last week while I was at school (car kept outside in below 0 weather) I had to let it warm up for half an hour before driving, because as soon as I touched the steering wheel, it would whine even more and I am afraid to break something.
When cold, the fluid is exactly like molasses. When it starts to warm up, the reservoir if filled with bubbles. There are no leaks and the fluid is right where it is supposed to be on the dip stick. I don't believe there is water in there, because I don't see any white, milky fluid.
I'm not sure if the pump is going? Rack and pinion wore out? Bad fluid?
I have no other steering issues other than there is a popping sound when turning the wheel quickly to the left. The car tracks straight and no vibrations.
All help is appreciated, thanks in advance.
Tried that, made no difference
Id either look into removeing 1 of the lines and fully drain it...
Or replace the power steering pump.../use it like it is til it fails
Or just deal with the noise....since it disappears....
Yeah, since there are bubbles in the reservoir, air is getting in somewhere. It's just weird that there are no leaks.
6th Gen ('00-'05): Whining/ Possible power steering problem?
aeceder
08-07-2015 10:27 AM
7th Gen ('06-'07): Power Steering Power Problem
TomF106SS
10-06-2014 10:13 AM
simdog765
11-28-2011 10:38 PM
