Water pump replacement
Old 09-09-2009, 11:18 AM
Monte SSV's Avatar
Default Water pump replacement
I had my water pump replaced twice under warranty - once for a bad bearing and the other time a seal. The motor is out of the car now and about ready to put back in, but I would really like to use an aftermarket water pump non-cast and/or billet housing if one is made for my car. It's a 2007 SS with the 5.3L. The OEM water pump is cast (made in China - and of inferior quality) with a pressed in bearing and can not be rebuilt because the housing can not take the pressure of bearing removal and reinstallation. Does anyone have any suggestions.
Fubba
04-10-2011 08:39 AM
Rich
04-13-2010 11:36 AM
pilotknob1964
10-03-2009 01:53 PM
sportjunkee
01-13-2008 07:13 PM
Brooke
10-17-2007 04:35 PM
Quick Reply: Water pump replacement
