answer me this and i will owe you.
almost
almost found a way to do enable the oil psi gauge in the ss-ls cluster swap.
I found the correct socket/signal switch part numbers.
i found the correct wiring into the pcm and socket,
but i need to enable it in the pcm from a (ok/not ok) to (ok/low) setting.
I finally had recieved a email back from hptuners that it doesnt have this capability.
think i could convince a service dept at the local dealer to change it????
Last edited by forgotten; 02-03-2012 at 09:06 PM. Reason: answer recieved by another source
there's been a few posts of how to do this here on the forum, i can't find the post atm, but just search around, from what I hear and remember seeing it wasnt too hard.
I'll post the link if I can find it
i have someone i grew up with that may have a tech 2..... if i have to ill call him next week.
04MonteLS
06-05-2005 03:41 PM
