right front brake sticking after pad/rotor change
Old 02-11-2010, 03:19 PM
Endo's Avatar
Default right front brake sticking after pad/rotor change
My right front brakes are sticking after I just changed my pads and rotor.
When I took off the old pads I noticed that the top and front of the inner pad was worn more and the back bottom of the outter pad was worn more indicating that something must not be level.
Has anyone seen this on their monte and have any ideas what it might be?
Thanks a ton! I'm stuck with no car until I figure this out!
Old 02-11-2010, 03:27 PM
Sounds like the right side caliper is going bad. You may want to rebuild both front calipers, since you install new pads. Did you get your rotors turned by any chance? If not, it'd be a good time to do that as well if they look/are/feel worn.
Old 02-11-2010, 03:39 PM
Caliper piston OR slider is sticking. Get a rebuilt caliper. They are cheap. Slap it in there problem solved.
Old 02-11-2010, 10:04 PM
caliper its best to replace both at the same time if you dont and just replace one it becomes a safty problem. as inspring a leak in the left one or not work all together on the bright side you can get the ones that say corvett on the side but it higher prised than the stock ones try to find a upgrade ones and go from there you will be happy if you chose a upgrade or the stock ones
Old 03-06-2010, 11:47 AM
can i get a direct site to rebuilt cailpers or suggestions to upgraded ones? Ive been skimin through pages all this mornin n yet to figure out the best buy for upgraded calipers, my driver side currently sticks, so therefore i plan on either upgrading or just buying some new stocks. I do have 22's so i would definately like some more stiffness on my brake pressure...so can someone let me kno what the best way to go...n i guess i can add some style factor as the big wheels reveal the whole brake assembly
Old 03-06-2010, 11:52 AM
http://www.wbodystore.com/grandprix/...es!-p-228.html
W Body Store GXP upgrade
The stainless steel brake lines will improve pedal feel.
Old 03-09-2010, 11:51 AM
r the 13 in rotors any use? or should i price those out somewhere else?
Old 03-09-2010, 11:55 AM
Yeah, use the ones he supplies they are the good ones.
Old 03-09-2010, 12:02 PM
cool...ill be orderin these this weekend...now they r direct fitment or r any mods required?
Old 03-09-2010, 12:14 PM
This is a straight up bolt on deal. Ur gonna love it.
ladybridgeport
02-17-2011 08:30 AM
goingforgold
12-17-2010 06:16 PM
mini64
09-29-2010 12:58 PM
sparx
07-29-2009 10:54 PM
04 Intimidator
06-08-2008 10:51 AM
Quick Reply: right front brake sticking after pad/rotor change
