Replace Elec. Quadrajet with Eldebrock Carb - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 06-15-2009, 09:45 AM
Default Replace Elec. Quadrajet with Eldebrock Carb
I have a 84 Monte SS with electronic quadrajet. I want to replace this carb with a non-electronic Eldebrock carb.
Emissions is not a concern.
Can I just tape off carb wires and bolt on the Eldebrock carb?
Thanks
Lonewolf900
Old 06-17-2009, 09:59 AM
skylark65's Avatar
sorry, but no. i did a similar swap on my 84 olds, 307 & that godawfull electronic Q-jet.
i replaced it with a non- electronic q-jet w/ a mechanical choke, and to do the swap you will need to find ( or buy new) a vacume controlled HEI distributor for your motor, and hook on an exsisting vacume line. your car should have an electronic HEI distributor currantly, which will not work with the edelbrock carb.
after i had my olds assembeled, it ran much better, but i should have found a vacume-choke carb, because i had to fab my own mechanical choke, a real pain in the butt. the swap was fairly simple, just make sure to plug any unused vacume lines, and i was very pleased with the results. good luck.
Old 06-17-2009, 10:17 AM
Thanks for the good info!
lonewolf900
Old 06-17-2009, 10:39 AM
skylark65's Avatar
no problem. i know any info on a swap like this is hard to come by, the only info i had to go on was " yha, it should work". the way i did mine was very cobbeled togeather & needed alot of refining, but i did find out it is possible & the car ran much better, although i think that it would never pass emmissions.
like i said above, the swap is fairly straightforward, but plan for some downtime because im sure there will be some bugs that need to be worked out
Reply
Thread Thread Starter Forum Replies Last Post
Eldebrock 750 carb Tazz76 PRIVATE For Sale/Trade Classifieds 1 04-28-2013 01:49 PM
will my centerbolt 305 quadrajet intake fit a 91 tbi 350? wvmontels Headers/Intake/Exhaust 3 02-02-2013 11:54 AM
6th Gen ('00-'05): To replace or not to replace Fuel Pump Module? Chris s Monte Carlo Repair Help 0 01-29-2013 12:11 PM
elec question HPNOTIQracing Monte Carlo Repair Help 4 11-10-2010 09:41 PM
help with tuning my rochester quadrajet djizzle Monte Carlo Repair Help 3 12-19-2006 02:38 PM
Tags
carb, carburetor, carlo, change, edelbrock, electronic, mechanical, monte, mw, problem, quadrajet, replace, replacing, ss, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
