Question about temperature sensor...
Old 08-13-2009, 08:05 PM
1984LCMonte's Avatar
Default Question about temperature sensor...
Hi everyone! The temperature gauge isn't working. I can't, for the life of me, find the heat sensor on the manifold. It is not the 305, but is 350 crate motor, if that matters. Anyone have any pics, suggestions?
Old 08-13-2009, 08:14 PM
The Popcorn King's Avatar
If my memoroy serves me right ( and i am sure that it doesnt ) its either ON the thermostat housing or the either the left or right of it or on one of the heads.
Thinking about it, i think its on the heads. Look there. Just below your exhaust manifold.
thermostat housing is where the thermostat is located!!!
Old 08-13-2009, 08:17 PM
Something else. best way to know if its the temp sensor is take off the wire and ground it. Your gauge should move. If it does, the bad switch. if it doesn't, then it could be either wiring or the gauge itself.
Old 08-13-2009, 08:24 PM
cancel my answer, wasn't thinking right, sorry!!! duh, it is on the intake manifold????
Old 08-13-2009, 08:53 PM
I'll definitely check it out. Hopefully it's just the wire and I can replace it. Thanks!
Old 08-14-2009, 05:54 PM
Just fixed it! You were right, it was right by driver's side header. Plugged it in, and voila! Thanks guys!
80Monte
05-13-2015 09:40 AM
00MonteCarloSS
08-06-2014 01:26 PM
spotthedalmatian
09-15-2010 10:14 AM
stringbander
11-09-2009 09:41 PM
hckygoalie31
11-15-2006 10:35 PM
Quick Reply: Question about temperature sensor...
