please help
please help
I have an 03 ss with 41xxx miles on her, and i go and put the key in the ignition, and i turn it to on or i start it which ever, and some times the cruse light will come on the dash(when it shouldn't be). and the message thing on the roof wont come on, and my heater wont turn on either, it might take a few mins before they come on and start working. but if i hit the top of the dash they start working right away. so im just wondering if anyone has had this problem before, and what i can do to fix it. thanks for reading and any help i can get would be great.
the bmc went out on my car 2 years ago and i had that replaced, and when that went out it was doing anything like it is now. because when that starts going out, my car would lock and unlock the doors, and pop the truck when ever it felt like it. so i know thats not what causing it. but im still stumped
Wiring diagram and start tracking the issues. Get a 12 pack of highlighters, every issue needs a different color and you highlight the wires going to that item with that color. when they all intersect you have the first suspect.
I agree with chibi it sounds like a BCM and any controller never acts like another when they fail. If you want it confirmed you will have to pay or find it yourself.
an update i was going to clean the connectors on the ignition switch, but i had my step dad hook up his scan tool to my car, and we did a few tests. and it came up with 2 fault codes, the two codes are a P1554C and a P1585C. and it said that it could be the passlock bad or the ignition switch being bad. so i called and talked to my local chevy dealer and told them what the scan tool said, and they told me that it wouldn't be the passlock, because that has to do with the security system and that im not having any problems with that. and that its more then likely the ignition, but "they" would still want to test it. now my question is, do they know thats what it is and are trying to screw me out of money? or should i just go by what the scan tool said and go with it and replace the ignition?
chevyONmine
08-01-2023 07:33 AM
86monte carlo
02-09-2012 07:46 PM
Emnasty600
07-08-2011 07:17 PM
