P0404 engine code
Old 07-13-2005, 10:42 PM
king2805's Avatar
Default P0404 engine code
I have an engine code P0404 showing up on my 2002 Monte Carlo. I replaced the EGR valve but this did not fix the issue. Please help! I am getting almost no power under load. Very slow accelaration.
Old 07-13-2005, 11:20 PM
Default RE: P0404 engine code
ORIGINAL: king2805
There are a myriad of things that can cause a "Exhaust Gas Recirculation Circuit Range/Performance" fault. I think you best bet would be to have it checked by a pro, it'll save you from replacing parts that don't need replacing. Good luck.
Old 07-14-2005, 07:41 AM
i would take it in but off hand i was thinking that is sounds like apluged Cat. when they plug up they will kill power and also you will notice the car will not run very well at idel ethier.
good luck
Old 07-14-2005, 10:34 AM
I am with Mickey on this one. We just had another member yesterday with the same type of problem. Good news is, it should be covered under warranty. 8 years I think.
Keep us posted..
KWJR86
07-12-2021 12:31 PM
getterdun
FWD Tech Guides '95-'07
10-17-2016 03:49 AM
augi
02-05-2011 10:50 PM
dustybird3
02-05-2008 08:18 PM
Bigg J
05-17-2007 06:48 PM
Quick Reply: P0404 engine code
