New Engine and Transmission
Well, I partially got a fix, and yet I'm still having a rough idle and misfire code. The coil was in fact corroded, which caused a spark plug and wire to foul out. However, this is apparently not the only issue. They are testing the injectors now, then they will test drive the car again.
I am so frustrated with the amount of time this is taking. I don't mean to be a whiner, but a few more items replaced, and I may as well say that replaced everything under that hood!
I know how you feel, I had a rough idle and misfire in my 02 SS, ( My Minion!) It turned out to be the same coil as yours. Two months later found the #1 plug and wire was bad. In the first 2 1/4 years I've owned My Minion, she must have spent 9 months or so in the shop. There was a point when I only got to drive her for a month and a half between NEEDED repairs. It was so depressing. The last thing I had to do was have the Trans rebuilt. That was August of last year. Now I have to replace the driver side ball joint. A minor repair. I have it, and I am just waiting for the weather to warm up so I can do it. IMO it has been worth every penny and bleeding knuckle I have put into it. I just recently had her check out by my Pro Mechanic at the local Pep Boys, the only ones I let work on my Minion. They said she's running great.
You got all the Major work done and now you just have to get rid of the Minor Bugs. I think you will not only be ready for the Shows, but you will place well I'm them! Good Luck!!!!!
Thanks for the encouragement, JC! I'm looking forward to the weather warming up and getting out there to some shows. Every car has its issues...I'm just lucky mine came up in a safe way. Some people are a lot less lucky.
How's your Minion holding up this frosty winter?
Hi Chis, glad to give you support. As I said in my last post I know how frustrating it can be. I too want My Minion close to show condition. She is my Daily Driver so she Will never be Perfect. And I really just want to enjoy driving a good looking car! She is doing well. Still no issues. The weather has cause me to have Pep Boys install the complete control arm. Turning tool on her in this cold is not my cup of tea. But for an Upper Middle Aged Gal, 190k miles on her, she is taking good care of me. And I try to do the same for here! What more can you do right?
You're right, all cars have there issues, it take an owner like you and I to see that despite those issues, our cars are worth taking care of. Be safe, and keep on giving he the TLC you know she wants and she will continue to make you smile!!!!!
Once again, another problem...
The crate engine I purchased to put into the car failed a compression test. Also, I found out that the injectors need replacing. So, I guess it's yet another week or two of waiting to get my car back.
Jethro
09-15-2013 09:24 PM
T Rell Rich
04-22-2013 10:34 AM
Visceron
06-20-2010 11:26 AM
