IGNITION & PASSLOCK SENSOR
well my car would not start over the weekend so i took it to my mechanic and the ignition switch & passlock sensor were sending false codes to the bcm making all of my idiot lights to come on also he said that the turn signals & flashers run through the passlock making them not work sometimes i have to pick it up tonight i will let everyone no if it works like it should thanks to evrybody for all of the help.
RE: IGNITION & PASSLOCK SENSOR
The passlock sensor can cause a no start condition,but it has nothing to do with your turn signals/hazard lights.The most common cause of intermittent turn signal/hazard light operation is the hazard switch.The module(flasher) that controls theturn signal & hazard lights is incorporated into the hazard switch.
Repair Guide: Ignition Cylinder Replace (Passlock fix)
psson24
FWD Tech Guides '95-'07
02-12-2012 06:46 PM
