4th Gen ('81-'88): Help with Tach
Old 03-29-2017, 08:26 AM
Torn151's Avatar
Default Help with Tach
Anyone help with hooking up a Tach ?? I have a 84 Monte & I got a tach out of a SS I want to put in. Mine has 2 metal pins on the back plastic and the SS has 4 metal pins.(see pics) 2 of the pins are marked with a - & +. what are the other two pins for ? Since mine has only 2, How can I wire it up to work ?
File Type: jpg
File Type: jpg
File Type: jpg
Old 03-29-2017, 11:31 AM
I am sure someone will post. I am not sure as I installed an aftermarket tach in mine and did not use the cluster wiring.
Old 03-30-2017, 05:25 AM
Torn151's Avatar
got it figured out
Old 03-30-2017, 06:11 AM
How did you wire it up?
Old 03-31-2017, 04:09 AM
Torn151's Avatar
Just Got the SS plastic back plate with the 4 pins on it, Then since my car didn't have an original tach, I ran a wire from the distributor to the white wire in the factory harness !!
Old 03-31-2017, 06:06 AM
Cool! Thanks for sharing
