HELP!!!! rear wheel bearing replacment... - Monte Carlo Forum - Monte Carlo Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 01-23-2011, 12:20 AM
Exclamation HELP!!!! rear wheel bearing replacment...
I need some help does anyone know how to replace you rear wheel bearing hub assembly on a 05 monte. Its cold out and i already have the wheel, caliper, rotor, the four hub bolts off, sensor disconnected, and i know i have to disconnect the e-brake cable and the 2 retainer screws to dissassemble the backing plate. My question is does the hub assembly and e-brake assembly just pull out now? I dont want to be prying on it if im not supposed to.
Old 01-23-2011, 12:24 AM
do you have ABS?
Old 01-23-2011, 12:29 AM
yes i already disconnected my sensor
Old 01-23-2011, 12:38 AM
maybe this will help? there is also a how to video!
http://www.1aauto.com/1A/wheel-beari...HR00036/316406
Old 01-23-2011, 12:50 AM
No it doesnt the how to is for a front wheel and the video is just for customer satisfaction, but thank you anything helps
Old 04-03-2013, 05:24 PM
Quote:
hey Bud,you ever get that hub changed? im looking at the same job and need a few pointers on what to do and not do.
Old 04-03-2013, 05:51 PM
03SSLE's Avatar
Quote:
This thread is a couple years old, so I don't know if you'll get a response from the OP or not. To answer your question, you need to remove the caliper, rotor, parking brake cable, ABS sensor connector (if equipped) and the 4 retaining bolts. The hub should pull off, but some require a little persuasion to pop off.
Reply
Thread Thread Starter Forum Replies Last Post
Rear Wheel Hub/Bearing Removal Radagast the White Monte Carlo Repair Help 0 08-17-2014 11:52 AM
02 monte rear wheel bearing assembly issue valvefloatss Tires/Rims/Suspension 4 10-02-2009 07:15 AM
Stuck WHEEL BEARING! Ugh! Help! Someairforceguy Monte Carlo Repair Help 9 12-31-2008 05:39 PM
STUCK WHEEL BEARING! UGH! HELP! Someairforceguy Tires/Rims/Suspension 1 12-26-2008 09:05 PM
Tags
05, 2000, 2005, assembly, bearing, bearings, carlo, change, chevrolet, hub, monte, rear, removal, replace, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
