Heater\AC blowing air on floor and defrost only.
I am trying to figure out why the climate control only blows air on the floor and defrost vents. I checked the vacuum line at the back of the engine, and under the passenger side toward the center council. Both are hooked up with no leaks. What else could be causing this? The temperature control works fine.
6th Gen ('00-'05): heater only works and stuck on defrost.
Lalozx
05-19-2015 08:20 AM
Emnasty600
07-02-2011 09:38 AM
shineman08
06-12-2011 02:14 PM
