6th Gen ('00-'05): drivabilty issues
Old 05-07-2014, 12:29 PM
eiddo's Avatar
Default drivabilty issues
hi,
I have a 2001 Monte Carlo SS. Last week I noticed some idle issues from cold start, engine would hunt a little for a few seconds then idle OK. Monday car nearly stalled on the way home from work. Engine idled very rough, barely made it to the shoulder of the freeway. Had car towed home, Pulled codes P0420, P0102, P0131, changed Idle Air Control Valve, P0420 ( EGR valve replaced 2yrs ago) code went away. Car started and idled OK. 5 minutes later restarted car very rough idle and stall. I let car sit for 3 hour tried again car started and idle fine. Tuesday I drove to work and home and several other places with no issues. Went out an hour later car started and stalled within seconds. From posts I have read on MCF sounds like it could be the mass airflow sensor? If it is mass airflow sensor should i just replace or try cleaning? Any help is greatly appreciated, took off work today to try and resolve this issue. Thanks in advance.
Old 05-07-2014, 12:34 PM
nitehawkjcb's Avatar
Sounds like the MAF is acting up, try cleaning it first.
Old 05-07-2014, 02:19 PM
eiddo's Avatar
I disconnected (electrically) mass airflow sensor, engine started and ran without stalling.
I cleaned mass airflow sensor, same issue, engine starts the stalls. Should I replace MAF sensor?
Old 05-07-2014, 02:25 PM
That's what it sounds like to me.
Old 05-07-2014, 03:05 PM
PacerSS's Avatar
What year is yours? I might have a MAF laying around
Old 05-07-2014, 04:50 PM
eiddo's Avatar
2001 SS
I looked at the MAF one more time. Female employee at Autozone noticed a huge chunk of dirt on the sensor. She told me to gently scrape it clean and replace air filter. I did, put it back in car reconnected it and engine started, idled and ran with MAF connected. I drove around a few miles no issues. I think I'm good to go.
Old 01-04-2015, 11:37 AM
not sure whats going on with mine,got the p0102 code today with the p0171 lean bank 1,been getting the lean code for a little while...
86montecarloooSS
08-16-2006 03:50 PM
mayerichm
03-03-2006 11:16 AM
jsteezy129
11-15-2005 10:47 PM
jsteezy129
11-15-2005 10:14 PM
GTown
11-11-2005 11:27 PM
Quick Reply: 6th Gen ('00-'05): drivabilty issues
