Fuel Injection Cleaner
RE: Fuel Injection Cleaner
ORIGINAL: ralphtrent
TVW, where would I get the Seafoam, normal auto parts store?
I use Marvin Mystery oil. You could add it to your gas tank or oil. Every time I use it I seem to get better gas milage.
I use kerosene right from the gas station. It costs 2.79 a gallon right now which is a hell of a lot cheaper than the over the counter cleaners. kero is a great cleaner and water remover. it lubricates well too. it will even increase your gas mileage. most of your fuel injector cleaners are made up of a form of kerosene anyway. just wear gloves. don't get it on your skin.
ORIGINAL: jfjohn
How much and how often???
you can use a quart for every 10 gallons of gas. I've even gone to a gallon for every 10 of gas. it gives you more power as long as you don't hear pinging. if your engine pings, don't use too much kero because it doesn't boost the octane that much and the ping will get louder than without kero because the kero gas mix has more energy than just gas alone so it will tend to make the ping stronger possibly causing more damage.
bigdomvegas
03-02-2010 12:50 PM
Monte Python
04-21-2005 11:46 PM
