fuel gauge problem
Old 03-26-2011, 11:52 PM
ndgrown's Avatar
Default fuel gauge problem
on my 2001 monte carlo the fuel gauge shows the correct level until the car starts moving and then it goes to full. also having problem with temp gauge occationally inoperative. both gauges are in the same cluster. any ideas what is going on?
Old 03-27-2011, 02:23 PM
Jon's Avatar
Jon
Jon is offline
i have the same problem in my 2000 monte(Gas), think it could be just a bad sensor
Old 03-27-2011, 04:28 PM
The gas gauge issue is probably being caused by a bad sensor. However, the temp gauge becoming inoperable, could be caused by a bad motor.
Old 03-28-2011, 05:24 PM
ndgrown's Avatar
does the fuel gauge and temp gauge have different motors , because both gauges are in the same circle cluster
Old 04-02-2011, 07:50 AM
Yes they do. Each needle has it's own motor.
Bobbydd21
07-23-2014 10:29 PM
01MonteRookie
02-25-2014 04:09 AM
UWAdventurer
02-14-2014 09:23 PM
robknight13607
03-20-2013 09:14 AM
04chevyboy
01-29-2012 09:50 PM
Quick Reply: fuel gauge problem
