Fixing a Dead Battery
Old 02-04-2007, 01:28 PM
Default Fixing a Dead Battery
Updated:2007-02-01 15:13:29
Fixing a Dead Battery By TOM MORR
[align=left]Cable Comparo
Obviously, cables are a prerequisite for jump-starting a vehicle. Not all jumper cables are built the same, and you generally get what you pay for. The thicker the cable, the more electrical current can flow -- and the higher the price of the jumpers.
Quality cables are available in thicknesses ranging from 10- to 2-gauge. Ten-gauge is usually sufficient for starting batteries in four-cylinder vehicles in warm weather. As the size of the engine increases and temperature decreases, fatter jumpers will do the job better. Large motorhomes or farm implements that need jumping in northern Minnesota in January are best served with 4- or possibly even 2-gauge cables. Thicker cables will also stay more flexible at colder temperatures than cheap, thin jumpers.
Word of warning: If the cables get warm during use, it's a sign of too much resistance. Either the cables are too thin for the job or they're possibly frayed or have rusty clamps.
[/align][/align]Speaking of clamps, they also vary in configuration and quality. For side-terminal batteries, 45-degree-angle clamps often grip better than straight jaws. Like the cable itself, clamps also carry amperage ratings. Quality cables often have 400-amp-rated clamps, and industrial-strength clamps are even rated at 500 amps.
Cable storage is also critical. During jump-starting, the cables' jaws often pick up battery acid from corroded terminals. This acid is highly corrosive, so cable should always be stored in the bag that many higher-end models come in or at least in a thick trash bag. Otherwise, corroded cable clamps can slowly eat through your trunk. Furthermore, storage space often determines cable length -- the longer and fatter the cable, the bigger the coil it makes. Jumper cables are generally available in lengths ranging from 10 to 30 feet.
Preliminaries
First, inspect the dead battery. If it's leaking excessively or the case is visibly cracked, abort the jump-starting mission and replace the battery. A damaged battery won't hold a charge anyway. Besides, attempting to charge a battery that has a split case can eject acid, and you'll end up reenacting the Wicked Witch of the West's death scene from the Wizard of Oz.
Next, verify voltage. While a good 12-volt battery can charge a dead 6-volt battery in an emergency, it can also fry the 6-volt vehicle's lights, gauges, and other electrical accessories. Also inspect the battery terminals. Corroded studs and battery-cable ends will impede the flow of electricity from the jumper cables into the battery, so clean the posts and cable ends as well as possible. Remember to keep even dried battery acid away from skin, eyes and lungs. Wearing eye and skin protection is always advisable whenever dealing with batteries.
[/align]
Park the vehicle with the good battery within jumper-cable distance of the dead car. Make sure that the cars aren't touching. Both vehicles should be put in Park (automatics) or Neutral (manuals) with the parking brakes set and all accessories such as headlights, dome lights and radios off. Turn both ignitions to the OFF position. Unplug any cigarette-lighter accessories such as radar detectors and cell phones -- jump-starting can send a voltage spike through the vehicles electrical system and burn out these gadgets.
At this point, if either battery has removable vent caps, pop them off and cover the holes with a rag. This allows hydrogen gasses to escape during jumping. If rags aren't available, then make sure that the caps are firmly seated.
After checking the caps, identify the batteries' positive and negative posts. (Many newer cars have terminal covers over the positive post; others that have tight-access battery locations use remote jumper studs.) Then prepare the jumper cables by uncoiling them and separating the positive and negative cl
TheMonteMan
09-23-2009 02:27 PM
Laserblue06ss
07-11-2007 01:44 AM
bilms01
04-13-2007 05:58 AM
bilms01
04-04-2007 10:23 PM
06BlackSS
03-27-2007 02:29 PM
Quick Reply: Fixing a Dead Battery
