Dreaded Leaking Lower Intake Manifold Gaskets
Old 02-05-2011, 04:51 PM
jimbo7's Avatar
Default Dreaded Leaking Lower Intake Manifold Gaskets
Well, it's now my monte's turn to have those wonderful l.i.m. gaskets replaced. It has 86k on the clock, so it's right on schedule that it would start to leak. Thankfully it's just a very slow coolant leak on the outside. I haven't been driving it lately so it doesn't get worse or more messy. Another bad thing is that it's so cold and snowy here, that I won't be able to fix it for a while (i have another car to drive in the meantime). I wish I had a garage to work in.
I've done some research and haven't really come up with much info for the supercharged 3.8's. Would I need to remove the supercharger from the intake? Do I have to remove the injectors? Do you really need to reomve the valve covers? Torque specs? What other things do I need to worry about?
I need to know what parts I need and how to go about fixing this.
Also, I'm gonna change the plugs and wires while I'm at it (they are originals). I might go one step colder since I'll be making it breathe a little better this summer. Probably replace the belts and put a cooler thermostat in too.
Old 02-06-2011, 02:06 AM
nitehawkjcb's Avatar
Yes, you have to remove the injectors and the supercharger, and the lower intake. There are your gaskets. You might as well do the valve cover gaskets too, it's only a matter of time for them to fail as well.
jimmyfloyd
04-20-2018 12:46 PM
toasterlocker
10-17-2013 09:30 PM
Furder2010
04-29-2013 02:23 PM
Shandley
02-01-2012 08:44 PM
BeachBumMike
03-15-2011 10:18 PM
Quick Reply: Dreaded Leaking Lower Intake Manifold Gaskets
