Debris in Power Steering Pump Reservoir
So today Murphy's Law struck as I was doing some routine maintenance on our '02 MC. After sucking out all the old power steering fluid, I was preparing to pour in some new Lucas power steering fluid. Just as I was preparing to pour, the conical-shaped cap from the Lucas container slipped out of my hand and, of course, dropped right into the power steering pump reservoir opening. I couldn't have done that on purpose if I tried. I have been unable to get it out. I can't even see it anymore. It was visible at first, but I must have pushed it out of sight. I refilled the reservoir in the hope that maybe it would float to the top and make itself easier to find / remove. No luck so far.
Short of completely removing the power steering pump, a task I'd rather not undertake, does anyone have any other suggestions? Your thoughts on whether possible damage could occur if I drove the car for now with the cap still in the reservoir? I guess it depends on whether the cap could block flow of fluid; I don't know how likely that is.
Maybe use one of those claw thing(see pic) to get into hard to reach places and just keep fishing around till you find it. I dont know what is inside the pump but was wondering if there is anything in there that would just grind it up. good luck and I agree you couldn't have done that if you wanted to.
Cool looking claw tool. Never saw one before. Maybe I'll try to find one.
I think the cap fell down the deeper / narrow section of the reservoir. I fished around for a long time with a coat hanger with no luck. Frustrating to say the least.
Do you have an AutoZone near you? It says special order so you'll probably have to pay for it then pick it up later, or maybe check out other part stores in your area.
OEM/4 prong claw flexible shaft pick up tool (25291) | Magnetic Pick Up Tool | AutoZone.com_
No offense, but it's refreshing to see that Mr Murphy messes with other people too rather than just me. My luck would have been the same as yours...
Thanks, Mike. There is an AutoZone in town. I'll check it out.
Not to worry... Murphy isn't neglecting others to pay sole attention to you. He's been alive and well in our garage far too often lately.
ChibiBlackSheep
FWD Tech Guides '95-'07
18
05-08-2017 02:23 PM
6th Gen ('00-'05): Power steering reservoir ...
Zeke
09-15-2016 08:51 AM
