dash removal
dash removal
right know im just playing around taking things apart trying to learn some things.i cant figure out how to take the dash board off,i got the four front screws off but it seems something in the back is holding it on.any help?thanks
RE: dash removal
Open the glove box and there is a screw on the left hand side toward the center. Then open the driver side door, take off the fuse box cover and there is a screw on the right hand side close to the dash.
Also make sure you take out the key faceplate if you have a 2000+ Monte.
RE: dash removal
The firewall is the metal that sperates the engine bay from the interior of the car, roughly the whole back of the dash.
I'm trying to think how the top soft part of the dash is connected and can't remember offhand. I personally haven't taken it off, but I saw the whole dash being removed to replace a heating core but that was like a year ago.
If I remember or find out I will definately post it.
What are you removing it for anyway?
RE: dash removal
thanks for the info on the firewall,no reason on taking it apart just want to learn how to do it.i got the dash faceplate off and figured i would like to learn to disassemble some things for experience.if you remember i'd appreciate it.thanks
Jester_20
04-14-2010 12:12 AM
