Climate controls
Climate controls
About a year ago the number 1 and 2 settings on my fan control stopped working.....last night I lost numbers 3 and 4 and can only use the heat on number 5. Someone at work tells me there is a cicuit board of some type in the car that controls the fan speed and that it is'nt the switch nor the fan motor that has gone bad. Does anyone know if this is true and if so where do I locate this gizmo on my 01 Monte SS ? Any help would be greatly appreciated.
RE: Climate controls
[align=center]BackinBlack,[/align][align=center]Below are some links that may help you.[/align][align=center]Good Luck.[/align][align=center]I hope that it's just a dirty switch that needs cleaned.[/align][align=center][:-][/align]2001 Chevy pickup my fan switch only works in high speed, co...
2001 Chevy pickup my fan switch only works in high speed, could it be the switch. fuse or something else? It's not a fuse if it still works.
www.answerbag.com/q_view/330927 - 32k - Similar pages
http://www.answerbag.com/q_view/330927
My Wrangler heater fan only works in the HIGH posi...
2001 Chevy pickup my fan switch only works in high speed, could it... Chevrolet trucks and SUVs. Search for Answers. Ask a Question. Browse Members ...
www.answerbag.com/q_view/92874 - 40k - Similar pages
[ More results from www.answerbag.com ]
http://www.answerbag.com/q_view/92874
[/align]WikiAnswers - 1993 chevy s10 blazer fan motor my heat nor ac...
Where is the fan relay on your 1993 caviler? Where is the fan switch for a 1993 chev astro? Why is t
